Jan 24, 2023 12:34 PM UTC
ISSUE - Poor hardware encoding quality - Mac M1 PRO chip
The quality of exporting from Premiere Pro using hardware encoding on the new MacBook Pro with M1 PRO chip is extremely poor. I've tried exporting with multiple different projects and footage but the quality when exporting with hardware encoding is pixelated and blurred - the file size is also significantly smaller than the estimated file size.
There is no issue with software encoding and footage is as expected.
I've tried Premiere Pro 2022 and also gone back to 2021 and tried opening with Rosetta instead, still hardware encoding into H264 is extremely poor quality with file sizes less than half the expected file size. This only happens with hardware encoding.
jmvdigital
Jan 24, 2023 3:01 PM UTC
Personally, I was very afraid of this issue when I first got my M1 Max. But I rendered out a previous project when I got it (hardware acceleration, same preset as before), took 100% screen grabs of the same frame and overlaid them in Photoshop. There were minor differences in the noise/compression pattern, but one was not obviously better than the other. It was VERY difficult to tell the two renders apart. I've now rendered out several 4K 100mbps projects and have no concerns with the quality.
And as a commercial pro photographer/videographer working on client projects, I feel confident in saying the above. Maybe there's an issue, I won't deny it, I'm just thinking that either it's intermittent, affecting only certain machines, or certain PP settings are triggering it.
I know right - I don't get why more people are not complaining about this or raising it as an issue. It seems like people are not realising it - maybe they are not perfectionists and just assume all is OK with their exports?! Adobe/Apple need to sort this out! I don't know how to get it escalated to a high up developer to look into.
Very frustrating! - Just set up the new computer in March 2022. Macbook Max 16" and same issue. Can't render out of premiere! ****** compressed, jpegged image. Unusable! It's the entire reason to buy the new $5k computer!
Macbook pro M1 max 32go
I am having issues with this as well March 1st 2022. Hello, is there someone at the line?. H264 hardware is ok But I can't export with h265 Hardware encoding. The quality is very poor. Using software encoding is not an option as it takes forever to render.
10 minutes 8k, 60fps 360 video : M1-software encoding-80 mbs is like 5-6 hours.
The same render time is 40-45 minutes with previous PC 20xi9.
Try with premiere Beta and it is the same. It is very sad to build your project with the new M1 (very very fast editing btw), and find that you can not export at the end. Hope Adobe will react fast with this major issu as a lot of videomaker started to switch to M1 now. Yep, this 5000$ macbook pro is a real beast when editing, and largely faster than a 14k$ PC.
I have the exact issue with my projects for H264 exporting.
This issue was found when I switch to M1 version of Adobe products. it wasn't that noticeable with the Intel version using Rosetta 2.
Hardware encoding for H264 was unacceptable bad with anytime bitrate.
Software encoding was better but still have artifact with double bitrate.
the same video upload to YouTube and download the H264 version is looking better with the smaller file size.
I notice this since the first version of the Apple Silicon Adobe product, and now Feb 16, 2022 and this issue is not yet solve.
Here's some reference:
MacBook Pro (13-inch, M1, 2020) 16GB RAM 1TB storage
OS version: MacOS Monterey 12.2.1
Premiere Pro 22.2.0 Build 128
Media Encoder 22.2 Build 64
Format: QuickTime
Preset: AppleProRes 422
Quality: 100
Width: 1920
Height: 1080
Frame Rate: 50
Field Order: Progressive
Aspect: Square Pixels (1.0)
HDR Graphics White (Nits): 203 (75% HLG, 58% PQ)
Depth 8-bpc
Filesize:
00:29:48:37 / 51.46 GB
Format: H.264
Preset: Match Source - High bitrate
Width: 1920
Height: 1080
Frame Rate: 50
Encoding Setting
Performance: Hardware Encoding
Profile: Main
Level: 4.2
Export Color Space Rec.709
HDR Graphic White (Nits): 203 (75% HLG, 58% PQ)
Bitrate Setting
Bitrate Encoding: VBR, 1 pass
Target Bitrate [Mbps]: 10
Filesize:
00:29:48:37 / 1.64 GB
Format: H.264
Preset: Custom, base on “Match Source - High bitrate” double bitrate and software encoding
Width: 1920
Height: 1080
Frame Rate: 50
TV Standard: PAL
Encoding Setting
Performance: Software Encoding
Profile: Main
Level: 4.2
Bitrate Setting
Target Bitrate [Mbps]: 20
Maximum Bitrate [Mbps]: 24
Filesize:
00:29:48:37 / 4.54 GB
Using ProRes 422 Source upload to YouTube and download from YouTube
Format: H.264
Preset: unknown (YouTube)
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf58.29.100
Duration: 00:29:48.80, start: 0.000000, bitrate: 2390 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 2252 kb/s, 50 fps, 50 tbr, 90k tbn, 100 tbc (default)
Filesize:
00:29:48:37 / 534.4 MB
Tim Cone - no one from Apple or Adobe seem to care to be honest.
I am having issues with this as well and it is Feb 5th 2022. How has this not been fixed yet?!
Same issue for me. I try many bitrate including extreme high bitrate, and the picture quality still bad.
After many tests I decided not to use Hardware Encoder on Mac Mini M1 Quality is poor It works weird I could not achieve intended file size Its a pity that it doesnt work properly I must use software encoder witch is slow Slower than Intel i9 on PC
Anthony, I can see you found my original report! Just so other people can easily find it, it's here:
https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/44268828-bug-v15-4-1-h264-encodes-are-poor-quality-on-m
