Issue with a finished project of almost 36 minutes and am having issues with encoding, PP CS4
  • October 14, 2019
  • 7 replies
  • 617 views
I'm having an issue with Premiere Pro CS4, it did fine on a smaller project I did on the fly one evening when a huge thunderstorm (unusual where I live blew through and knocked my power (and others on my street) out. It was largely dark imaged with occasional lighning and thunder and basic graphics, rand for just over 9 nuinutes long, Premiere did fine with the editing but also with the rednering /endocing and it went straight to YouTube, no problem, but took time to process all that and upload.
Now, I have a much longer video, just short of 36 minutes long and used the same settings for it as it was to upload into YT as well as I made a custom preset for it.
Anyway, This clip was shot during the day one weekend so lots of details etc. Camera is the Canon Vixia HF-R500 that is AVCHD as the file source used, not MP4, the other choice (both videos started off as AVCHD clips).
This video clip was a little more advanced than the other in that I had music, sped up some clips from 100 to 250%, titles, simple cut in/cut out, same font/color as the previous video, nothing fancy, all cut type edits, again, not very fancy stuff here.
Well, this video clip has had to be editied I think 4 times, rebuilding it from the beginning twice in the process, once was the clips detatched to other clips when expanding/shrinking the timeline for some reason, necessitating a complete rebuild, then the lightning storm hit, knocked out the power and lost all that footage as it never got saved. 😞
So here is the rebuilt footage and now it's finished and I go to export, after hitting the in point and the outpoint, then export to AME and hit que to begin the rendering/encoding process. All looks great goes through the entire projects, shows the full length of the video but when I play it natively on the computer, it usually begins to play fine and about 13 sec's into it, the image freezes, audio lingers about 3 or 4 words before it stops and when that happens, the status button on the play line of Windows Movie, which had been moving as it should when playing correctly, suddenly shoots to the end of the clip and stops.
At one point, I got a major improvement, it will play fine well into the clip before the same thing, but I can move the pointer in Quicktime to get audio, but locked/frozen video so went on and tried to uploadd it to YT and it uploaded (again, takes forever at 1Mbps upload), then began to process when it then rejected the project as incorrect format, not supported.
Meantime, I look at the logs and AME can't indentify the issue causing the problem by saing unknown error when it does crop up, but other times, the encoding was "successful" but yet, I can't play the entire length.
So here is a copy and paste of part of the logs captured by AME and yes, note the different frame rates when the footage itself is 1080P/30, though the meta data shoes 29.97 (30) frames for the footage I'm working in.
10/12/2019 10:57:50 PM : Queue Started
- Source File: C:\Users\Owner\AppData\Local\Temp\partial deep kitchen cleaning_13.prproj
- Output File: F:\a partial kitchen deep cleaning_1.mp4
- Preset Used: 1080P youtube settings
- Video: NTSC, 1920x1080, 60 [fps], Progressive
- Audio: AAC, 320 [kbps], 48 kHz, Stereo
- Bitrate: CBR, 32.00 [Mbps]
- Encoding Time: 04:13:13
10/13/2019 3:11:32 AM : File Successfully Encoded
10/13/2019 3:11:32 AM : Queue Stopped
10/9/2019 6:39:51 AM : Queue Started
- Source File: C:\Users\Owner\AppData\Local\Temp\partial deep kitchen cleaning_12.prproj
- Output File: F:\Sequence 01.mp4
- Preset Used: Custom
- Video: NTSC, 1920x1080, 29.97 [fps], Progressive
- Encoding Time: 03:49:41
10/9/2019 10:30:03 AM : File Successfully Encoded
10/9/2019 10:30:03 AM : Queue Stopped
10/8/2019 6:43:14 PM : Queue Started
- Source File: C:\Users\Owner\AppData\Local\Temp\partial deep kitchen cleaning_9.prproj
- Output File: F:\Sequence 01_4.mp4
- Preset Used: Copy of 1080P youtube settings
- Video: NTSC, 1920x1080, 30 [fps], Progressive
- Encoding Time: 00:41:24
10/8/2019 7:25:04 PM : Encoding Failed
The Operation was interrupted by user
10/8/2019 7:25:04 PM : Queue Stopped
10/6/2019 9:27:02 PM : Queue Started
- Source File: C:\Users\Owner\AppData\Local\Temp\partial deep kitchen cleaning_1.prproj
- Encoding Time: 00:00:36
10/6/2019 9:28:04 PM : Encoding Failed
Error compiling movie.
Unknown error.
10/6/2019 9:28:04 PM : Queue Stopped
The PC setup in question is a Dell Optiplex 9020 with a Core i5 processor (4570) running 16GB of memory, Adobe CS4 Master Suite and utilizing Premiere Pro only here for this project. Graphics card is the Invidia Gegorce 610GT that I brought over from my old PC as I was retiring it, and it can go half height to fit the small form factor Optiplex, running Win 10 Pro under Win 7 compability and is stored on an SSD drive along with other programs and the OS. The scratch Disk and files where the finished project is stored after encoding is a standard HDD of 500GB.
Other than a reinstall of PP CS4, any other suggestions?
BTW, where the image stops on playback is in the middle of a longer bit of clip at the beginning, not at an edit.
Thanks, sorry for being long winded!
    ciddyguyAuthor
    Well, didn't get to checking it out last night as once dinner was eaten, a couple of glasses of wine later, I was too tired to think about it so this morning I got back to it.
    Apparently, when I went to delete the clip at the beginning that was giving me grief, There must've been a cut inserted that I was not aware of and had split the entire clip into two. Deleted what I thought was the entire clip, hit play to watch the timeline and a section of the same clip repeated, so did a ripple delete and shifted the titles as needed down and re-rendered the the work area and am now seeing if the AME will render properly.
    On this system that'll take much of the day at the very least to do but once it is finished encoding, I'll be able to check it in Windows Movie and see if it plays correctly. If so, THEN I'll begin to upload to YT.
    ciddyguyAuthor
    That did not work, the issue still remains and spent time this evening, even though tired, not seeing any PRV files and not sure how to procede, but what I DO know is I should have removed the offending clip from the timeline and reinserted while back at a previous unrendered state. Oh well, so how to fix without having to redo entirely?
    Hope I'm makine ANY sense here.
    ciddyguyAuthor
    OK, I was able to get back to what I think was a pre-rendered state and replaced the suspected clip at the beginning and then re-rendered the entire sequence again before encoding.
    Well, it went through, no errors found in the error log, the main log shows it to have been a success endoding, so opened it up in Movies and TV and not quite in the same spot, but closer to the beginning, the issue reappeared as in, it began to play, and then the image stopped and the curser shoots to the end.
    I am wondering if H264 is not properly supported by that program, and if so, what will work? The thunderstorm footage plays fine as it is also an H264 file., just much shorter.
    Anyone have any ideas?
    The only other thing I could do is try to upload and see how YT takes it?
    ciddyguyAuthor
    Ah, that would make sense, will check there when I have more time this evening.
    Where does PP store rendered files?
    Cannot remember exacly: but might be scratch disks in the project settings.
    ciddyguyAuthor
    No, not using the PRV files. I render as I go editing the project, sometimes the actual workspace, other times the entire timeline as it is at that moment.
    In my Documents folder is where the Adobe content stuff is stored (default), as well as the encoded files etc are kept. I output the encoded files and it is saved in the file storage folder on the second drive for later uploading.
    Delete rendered files.
    Do you need to render. Are you using preview files?
    ciddyguyAuthor
    Thanks, odd as it's in the middle of a clip. All edits are cuts and this clip had a tittle but the error is after that title. Will remove and and reinsert as it looks rendered as the entire status bar at the top is all green. It could be something later horked that clip somehow. Will try later today when I have time.
    Somewhere around .37 and .41 seconds (see log) you have an issue on the timeline.
    Can be anything: corrupt clip, transition, audio, 3rd party plugin, you name it.
    Delete the section in the timeline and do it again. If its just a clip; convert.
    Did you use Render Max Render Quality from the flyout menu?
