patrickx007
Issue with Audio Track Playback When Switching Tracks in Premiere Pro
  • February 19, 2024
  • 260 views
I'm reaching out for assistance with a peculiar issue I've encountered in Adobe Premiere Pro. I'm currently using Premiere Pro version 24.1.0 (Build 85) and also testing the Premiere Pro Beta version 24.3.0 (Build 35).
Here's the problem: When I import an audio track into my timeline on track A1, the audio plays back perfectly. However, as soon as I move the same audio clip to track A2, there's no sound at all.
I've attached screenshots to illustrate the issue more clearly. The screenshot with the numbers 1, 2, 3 highlights my audio track in Premiere Pro version 24.1.0, and the one without the numbers is from the Premiere Pro Beta version 24.3.0.
One thing I've noticed is that there are icons appearing in version 24.1.0 that are not present in the Beta version 24.3.0. I'm wondering if this might be related to the audio issue I'm facing. I've compared the settings in both versions but couldn't find any differences that could explain this anomaly, other than the icons I've outlined.
Clicking on the icon where I marked "2" in the screenshot of version 24.1.0, I see a list of audio channels. When I switch it to "2" channels, the second audio track (A2) plays, but only on the right side of my speakers, and the first audio track (A1) plays on the left side.
I'd like to resolve this issue so that both tracks play back through a single channel. Could anyone please provide some guidance or suggestions on how to fix this?
Thank you for your time and help!
Correct answer patrickx007
UPDATE
I uninstalled and reinstalled the application, and the problem was solved
patrickx007
patrickx007AuthorCorrect answer
UPDATE
