Issue with Captions "Edge" Bleeding
  • November 1, 2018
  • 8 replies
  • 3171 views
Hey everyone, I am having an issue with my captions bleeding. Below is the information of what I currently use for font, size, and edge and also an example. It is usually just with the letter "w" where it bleeds on both sides of the black edge. I've tried messing with the fonts, edge, size but it still affects the "w". Do you guys have any solutions for this? Let me know! Thank you!
Stan Jones
The underlying issue is "miter limits." It was improved in captions in the 13.0.0 release, and fixed for regular PR text (essential graphics) in 14.0.0. (Current version is 14.1.0.)
Yes, very frustrating.
Stan
Stan Jones
Not fixed as of PR 2020.1.0. Different fonts have different tolerances for edge settings to show the problem.
I linked to this other thread above. It lists the main workarounds.
https://community.adobe.com/t5/premiere-pro/captions-egde-leak-problem/m-p/10730136?page=1#M236552
Stan
What a horrible premiere mistake, how is that possible? i cant believe it
I have the same problem, and i change the font but all fonts look with the same problem ¿did you solve it?
Stan Jones
vanessawn, I think the current status is still what I describe here:
What font are you using and what is the pixel size of your sequence?
Stan
caroline_edits
Hey there, Callie.
Is your font still bleeding? Did it improve if you changed the font?
Let us know!
Caroline
I have encountered the same problem (font 36, needing thick edges due to light background), tried changing the font but I have not found one which does not 'bleed' please let me know if a solution has been found....
Stan Jones
What frame size for the sequence and caption stream (you cut that off of the screenshot). Size 100, edge 20 is huge in my test 1920x1080. Comic sans has more of this problem than some others fonts. Experiment with reducing the opacity of the caption block background - all the way to zero sometimes looks better.
What specific dot version of PR? Interesting that your caption text is centered vertically in the caption background. There is a problem where in is at the bottom in some PR versions.
You are in part also experiencing the "spikes" that are a known issue. Vote here:
Edge rendering issue on close captions – Adobe video & audio apps
Edit: Went to dinner before responding, and when I hit send, I see this and 2 more responses in 6 minutes! lol.
I can reproduce the issue, reduce the edge.
Issue is only on the w.
caroline_edits
Hi Callie! Sorry about the bleeding, that's annoying. I set up a textbox in Premiere Pro CC to attempt to duplicate this problem and I was unable to do so. I have a few questions that will help me find a solution for you!
What version of Premiere are you using?
What system are you using? Mac or PC?
Let me know! We'll figure it out.
-Caroline
Hi, thank you for getting back to me. The frame is 1920 X 1080 for the captions (captions take up about 1/5 of the screen). I noticed that if I use "Legacy Title" instead, it works out. Let me know if you have a solution for the captions, I don't really want to reduce the edge because that is the style for the video. Thank you for your help!
Stan Jones
That is just odd. The edge is huge for me with that frame size.
Does it look the same on export?
Do you have any scaling set? E.g Windows display settings. (But I think that would just make it worse if it had any effect.)
