Issue with keyframing
  • November 17, 2021
  • 3657 views
UGG this is going to be one to explain. I still consider myself a newbie so all do y best to explain and include screenshots. Ive been trying to make an intro video to a possible you tube channel. I found a video template and i wanted to have the title of the channel roll across the screen in smoke and then roll back out and dissapear. I found a video however it succceeds in rolling out the title but doesnt roll it back. So i tpyd around with the key rames trial and error for some time and i was actually able to get the title to roll back and disapear however ive been beating my brain for the last hour and i just cant figure out how to get the smoke to roll back with the title. I hope i explained this correct and i dunno maybe its something simple im just not doing. any help would be appreciated.
V1 : Template
V2: Smoke effect
V3: Text completed using Legacy option
Screenshot #1 Smoke effect moving to left revealing the words.
Screenshot #2 Text retreating without the smoke following.
Also if you have nay questions that might help please feel free to ask as i will be checking this post often. Thank you.  ALso im using PR 2021 with Widows 10.
try what Richard suggested, also try to duplicate or make a copy of the smoke video,
rotate it 180 deg. and make it start where the text starts wiping out.
All try and i posted a video of how the smoke isnt rolling with the words but all try to duplicate it.
If you can send me the files either by Dropbox or your CC account I can have a look at them and see if I can create the cloud effect you want.
Hey Richard i just wantedto saythanks for the offer but i have to be able to own up and say this has just gone beond my real of knowledge combined with the fact ive worked on this so long im getting totally behind my narrtion writing and story designs. I still hung with the smoke though i just decided though to do a double left to right wipe. Pehaps not what i originally had envisioned but loks good though. Thnks again have a great day
Peru Bob
If you want both the title and smoke to move together at the same time, highlight both clips, right click, and choose nest.
Then apply your keyframes to the nest on the timeline.
If that's not what you want to do, please explain it in more detail or a different way.
Hello bob first id like to say thank you for taking the time to help. I did as you advised and i nested the clips together (smoke/Text). However when i hit la back its unfortunately still doing the same thing. The soke and the text roll out and then the tetxt rolls back and dissapears like i want but the smoke doesnt come with it.
I was just rereading what you said. You said apply the hest to the timeline i dnno if thats something differnt from what ive done. So ive included a screenshot.
