Issue with opening project or create new project Premiere Pro CC 2020
  • November 23, 2019
  • 10 replies
  • 10295 views
I have been using Premiere Pro for a while, but only sporadically. I tried to use it today, and ran into some issues. I used it earlier in the week without issue.
I made a short video to better describe my problems that I can in writing, but basically I can't open an existing project. When I click open everything disappears. I also cannot create a new project. When I click on browse to put the project in a specific folder nothing happens.
I have tried various things. Initially I tried to remove cache and profiles based on a thread I found on here. That did not work. I tried uninstalling and reinstalling Premiere. Nothing. I tried uninstalling and reinstalling all the Creative Cloud. Still nothing. I tried resetting my computer to a state from a month or so ago when I know Premiere was working. That did not work. I tried reinstalling the OS but not the other files. That didn't work. Finally, I wiped the hard drive and reinstalled everything. Same problem.
Correct answer Kevin J. Monahan Jr.
 Lehlohonolo,
Looking at the video, it looks as if the OP is browsing for project files in his iCloud disk. If you also have an iCloud disk and store project files there, that might be at the heart of the issue. Personally, I have completely uninstalled this Apple service from my workflow and no problems since.
June 21, 2021
Hi Bradley, may I please know if you did manage to find help? I'm experiencing the (exact) same problem to the extent where I had to reset my entire laptopto default settings and remove everything. Still won't work 😔
Please help if you managed to find a solution. Thanks in advance 🙏
Never really found a solution. At some point software updates seemed to
resolve the issue. --
Bradley Durham
Graphic Designer
GetBranded.rocks
Resetting preferences is another thing you can try,.
Press Alt (Windows) or Option (Mac OS) while launching Premiere Pro. You can release the Alt key or Option key when the splash screen appears.
Read more at:
https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158
Can you browse and find files OK with other Adobe products like Photoshop?
I can browse and find files & create new files in all other apps I have installed: Indesign, Photoshop, Illustrator, Xd, and Lightroom; except Premiere Pro and After Effects.
I did try reseting preferences. No help.
I was on chat with Adobe support for a few hours Friday night. The tech support person admitted that this is a known issue with some Catalina installs. Awaiting a call back from them today to hopefully either come up with a resolution or get a time frame for a fix.
Sammy Kumar
This is honestly ridiculous. I'm having the same issue as well. The browse button throughout the application doesn't work period. I've tried uninstalling and reinstalling numerous times, trashing my preferences, googling this to the ends of the earth but no luck. About to switch to FCP over this.
