Lagging without using all resources
I am using Adobe Premiere Pro CC since a few days. Today I wanted to start a project, but evey time I want to work with videos in 1080p Premiere is extremely laggy.
My hardware is the following: Ryzen 1600, GTX 1060 6GB, 16GB RAM (only 3 GB are reservated for the system)
I am working on an SSD, I cleared the cache, and under the settings CUDA support is enabled. If I watch the task manager while playing the preview, the CPU uses less than 30% of their capacity, GPU uses less than 10% and approx. 5GB Ram are used.
The preview is set to 1/4.
I do not now what I should do to get rid of the lag, but it is impossible to edit a video like that. I do not have used effects until now, it is still the raw cut.
The video files are from a smartphone and filmed in 1080p. The whole length of the clips is 7 minutes in total (each 10-30 seconds).
Do you guys have any idea what else I can try?
Best regards
