Apr 16, 2025 9:44 PM UTC
level sound on timeline: sound is distorted
level whole track sound on timeline
 When I want to level the sound on the timeline in adobe premiere it doesn't work. if i select all and select audio gain and 'use the option Normalize All Peaks' and choose 0 db or -3, one clip is good, but the other is distorted. What to do?
Apr 17, 2025 12:41 AM UTC
Hey @Evitaadama,
Thanks for the question. Are the sources from the same camera? Is there any other information you can share?
