LogiOptions Panel appears in Premiere Pro
  • January 23, 2019
  • 4 replies
  • 21456 views
I have a Logitech MX Master mouse that I use on a Windows 10 computer.
The problem I'm having is that Logitech's mouse software has appeared to have installed some sort of panel within Premiere that opens up with any project I'm working on. If you close the panel, it pops back open after a certain time. The panel has no obvious function, and it bugs out when resizing. I have seen suggestions of uninstalling Logitech's "Options" software, but I use this software to control the buttons on the mouse.
It's extremely annoying and gets in the way of Premiere's functions.
Any tips?
Premiere Pro Version 13.0.2 (Though it's been happening through several versions)
    Correct answer mooretho
    LogiOptions extension exists in the following path.
    C:\Program Files\Common Files\Adobe\CEP\extensions\LogiOptionsAdobe
    You can move the LogiOptionAdobe folder from this folder to another folder.
    Then, the LogiOptions panel has disappeared from Adobe application in my case.
    You need not uninstall.
    THX!
    WIn11 + g300s
    The problem is solved, thanks to you
    RC Ducantlin
    Are you kidding me?  We should accept the answer is to move a folder to stop an erroneous pop-up from occuring?
    What is the correct answer to this problem?
    Roger
    Peru Bob
    quote
    By @RC Ducantlin
    You may want to ask Logitech.
    howardt51961349
    how do i do this for mac? we dont have the same extensions????
    benoith54182239
    Hello! Same issue here, resolved it!
    Macintosh HD⁩ ▸ ⁨Bibliothèque⁩ ▸ ⁨Application Support⁩ ▸ ⁨Adobe⁩ ▸ ⁨CEP⁩ ▸ ⁨extensions⁩
    Sorry it is in french, but I guess it wont be difficult to find your way with this info.
    I've just move the LogiOption folder to another folder (below extension worked for me).
    Hope it will work for you 😉
    mooretho
    moorethoCorrect answer
    mikec16898856
    Thank you!!
    Peru Bob
    Try installing an older version of Options.
