Feb 19, 2026 9:19 PM UTC
Looking for VFR (Variable Frame Rate) Problem Files – Help Us Improve Premiere's Editing Experience
Hi everyone!
I’m a Product Manager on the Premiere team working specifically on improving the Variable Frame Rate (VFR) editing experience.
We know VFR footage can introduce issues in real-world workflows, such as sync drift, stuttering playback, unexpected frame duplication, audio misalignment, export mismatches, and other inconsistencies. We’re actively exploring ways to make editing VFR footage in Premiere more predictable and robust, and we need real project files that have caused problems.
If you’ve run into VFR-related issues, I’d greatly appreciate your help.
What we’re looking for
Please PM me with:
  1. A link to the project file and media (Dropbox, Frame.io, or similar works well)
  2. A clear description of the issue
  3. Reproducible steps if possible (what you did, what you expected, what happened instead)
  4. Your hardware specs (CPU, GPU, RAM, OS version)
  5. Premiere Pro version
Common VFR Sources We’re Investigating
  • Phone footage (iPhone, Android, Samsung, Pixel, etc.)
  • Screen recordings (OBS, XSplit, Loom, Zoom, Teams, etc.)
  • Gameplay captures
  • Webcam recordings
  • Mixed camera workflows where some clips are CFR and others VFR
Even if the issue seems small or inconsistent, it’s valuable to us. Edge cases help us design more resilient behavior.
Thanks in advance to anyone willing to share files and workflows, I'm looking forward to hearing from you!
    hunting
    Mar 18, 2026 7:39 PM UTC
    Thanks ❤
    Shebbe
    Mar 18, 2026 5:15 PM UTC
    I just want to say thanks for looking in to this.
    In our facility we use a workaround where we preconform all phone footage we get to fixed 25fps before editing to remove all related issues. So I won’t be able to give any useable recent data but I’m happy it's being taken seriously and hope to see a solution that can remove our workaround.
    Mar 13, 2026 8:53 PM UTC
    You know what you could do, stop releasing new versions every year when they aren't ready. You could use that time to work through the years of bugs and feature requests you already have.
    Peru Bob
    Mar 13, 2026 10:59 PM UTC
    ​@real_5081
    I understand your frustration, but your reply is neither helpful nor appropriate for this thread.
    An Adobe employee is attempting to gather information in this thread to address one of the issues you have referenced.
    Mar 6, 2026 12:26 PM UTC
    Thanks for looking into this.
    I can share plenty of VFR material from promotional and social media projects (mostly iphone footage), but in my experience the main issue isn't necessarily playback or export. Premiere generally handles that fine as long as everything stays inside the timeline.
    Where things really fall apart is proxy generation.
    With VFR footage, attempting to generate proxies always completely cripples my machine. My observations are that since the frame rate is fluctuating, Premiere struggles to lock the proxy generation to a consistent frame rate, which makes the process useless.
    Interestingly, I rarely see this issue in Resolve. From what I understand, Resolve tends to conform VFR footage to a constant frame rate on import (or interpret it more predictably), which allows it to generate proxies without issues.
    A possible improvement could be something like:
    • Detect VFR on import
    • Offer an option to conform to the closest constant frame rate (e.g. 23.976 / 25 / 30) before proxy creation
    Right now my workaround is usually to transcode the footage to CFR before editing, which solves the problem but adds an extra step.
    That said, part of the problem also comes from capture devices themselves. Phones and screen recordings default to VFR, but now that many devices market “professional” video features (e.g. Blackmagic Camera app), it would be great if constant frame rate recording became more standard to avoid these issues altogether.
    Happy to share sample files if helpful.
    traindevie
    Mar 5, 2026 10:15 PM UTC
    hi
    this may not be related to VFR but can you tell them to add shortcuts for presets (effects, transitions) plz
    i did post about it but its been a year no respond
    jamesmite
    Feb 28, 2026 3:26 PM UTC
    Really appreciate you reaching out to the community about this. VFR issues can definitely be frustrating, especially with phone and screen recordings, so it’s great to see the team actively working on improvements.
    I’ll gather a sample project and system details and send them over via PM. Hope this helps make the VFR workflow more stable for everyone!
    AndrewTheGreat
    Feb 25, 2026 9:02 AM UTC
    I’d suppose, to reproduce this notorious problem, you’d only need a really long footage from a cellphone, like an hour or two long, cut heavily. it’s normally a 99 out of 100 case of a VFR drift scenario.
    I really wanna help and give you some VFR footage but since it’s always been a problem I now demand a CFR only footage from my clients or convert it to CFR.
    ​@Boka2112
    Because there are different scenarios like zoom, OBS records. People usually don’t bother themselves with video editors’ problems and shoot as is.
    Stop trying to edit and EDIT!
    Adobe Employee
    Mar 3, 2026 11:22 AM UTC
    Hi Andrew,
    Thank you for posting details — I appreciate you taking the time!
    One quick check: Does this still happen in the latest version of Premiere ?
    would you be comfortable with a conference call to dig deeper?
    Thanks again!
    Abhishek
    Feb 25, 2026 3:32 AM UTC
    Why not cbr and ditch vbr? Is it because of a great size difference? I only use cbr because vbr make transitions look like garbage.
    Shebbe
    Mar 18, 2026 5:12 PM UTC
    Easy to misread it if your brain is in lazy mode:) This topic is about variable frame rate not bit rate. VFR video encodings/recordings are ‘consumer’ level optimization solutions to be efficient with storage but becomes a crux in post-production where your timebase is a fixed grid.
