Low sound output when exporting to media
  • May 2, 2023
  • 969 views
When exporting a Premiere Pro project into Media, when playing the file, the sound is very low whereas, in the Premier projet itself it is quite correct.
What setting should I check to ensure that sound level is the same in the exported file as in the project constructed?
Correct answer Peru Bob
Use the audio meters to set the volume level.
https://helpx.adobe.com/premiere-pro/how-to/understand-audio-level.html
Different players may have different volume levels.
Peru Bob
fdormoyAuthor
Yes, you are right.  Choosing Media Player for playing the file was a bad choice.  Not recommended for use.  Better use Windows Media Player legacy.  The sound level was correct with it.  So it is not a matter of a wrong export settings but rather a wrong application.
