Oct 26, 2026 9:35 PM UTC
M1 Max fans louder with Premiere Pro
Hi.
I’m using Premiere Pro 26.5.2 on a Macbook Pro 14” M1 Max 10/32 64 on MacOS 15.8. I have a Caldigit TS4 plugged into it.
My main UI screen is a LG4K external monitor plugged into the TS4 (DP-->DP). I’m using my Macbook screen as a second monitor. An EIZO CG247X, plugged into the TS4 (TB-->DP) is used for Transmit.
Firsly, I noticed the fans are spinning louder if the LG is not set to its native resolution.
Secondly, I noticed the fans are spinning even louder when enabling Mercury Transmit on the EIZO (set to its native resolution).
Lastly, on another note, I noticed the timeline is less snappy when I put the Audio Track Mixer on the Macbook screen.
I don’t recall fans getting louder under these circumstances with prior versions of Premiere, because I noticed it in the last weeks (and I thought it was related to decoding some files, but it’s not).
I just wanted to know if these issues ring a bell to some of you, as it becomes more annoying to work with my M1 Max, which was silent before (not when exporting, but that’s not an issue).
Thanks!
Max
    Kevin-MonahanCorrect answer
    Oct 27, 2026 7:31 PM UTC
    Hey there Maxime,
    Oh yes, it's vital to plug the monitors into the proper ports- the fastest ones possible on the machine for the most demanding task, like monitoring. I think some Thunderbolt ports are faster than the rest, so check that out. There should be a configuration guide somewhere on https://adobe.ly/3UfyNyB. Also, check out the CalDigit website and let me know what you find out. I also have that machine and am moving to a new MacBook Pro right now. The M1 is starting to get a little long in the tooth after 6 years of hardcore use! Let us know what works out.
    Oct 27, 2026 7:40 PM UTC
    OK so I switched the EIZO to DP-->DP and the LG to DP-->TB (switching the monitors ports):
    Transmit off: fans completely silent
    Transmit on: fans running but clearly not as loud as before (when playing a 444 Prores UHD HDR file or a “standard” H264 HD file).
    So I guess I switched the displays when moving my desk and I didn’t think it could lead to more GPU usage! Maybe it’s a USB dock thing? Anyway, if someone can confirm that its M1 Max spins the fans when using Mercury Transmit, it’d be much appreciated.
    Also, I can confirm that when the Audio Track Mixer is activated on a screen (regardless of which one), the timeline is a little bit less responsive, scrubbing is not as smooth as when the panel isn’t open.
    Oct 26, 2026 11:33 PM UTC
    Hi Max,
    Thanks for the detailed report. I'm curious how Premiere Pro performs when you disconnect the CalDigit TS4 and all external displays and work exclusively on the MacBook Pro's built-in display. Are the fans still louder than usual, and does the timeline feel more responsive?
    Also, when was the last time everything worked as expected? Do you recall which version of Premiere Pro and macOS you were running at that point?
    Has anything changed since then, such as a Premiere Pro or macOS update, display settings, dock firmware, or anything else in your setup?
    Knowing whether the behavior occurs without external devices and what changed around the time it started would help narrow down the cause. I hope the community can assist.
    Thanks!
    Oct 27, 2026 8:38 AM UTC
    Thanks ​@Kevin-Monahan.
    When I work exclusively on the Macbook Pro, it’s completely silent and the timeline is smooth as usual. I did not test with the Audio Track Mixer panel open.
    It’s hard to tell when it did work as expected, as I switch projects very often. I’m pretty confident I did not have loud fans when working with PP25.
    But I recently moved my desktop around my room, unplugged everything, and then I might have switched the external monitors from the DP to TB ports of the TS4 and vice versa. Could it be the cause of the fans being unusually loud?
    Kevin-MonahanCommunity ManagerCorrect answer
    Hey there Maxime,
