Match Frame no longer sets out point!
This is incredibly frustrating. Abobe, why did you change this?
version 25.0 / premiere / sonoma 14.7
In older versions, "match frame" would show the used clip, both in and out point in the source monitor. This was useful for when I would need to replace the raw media back into the timeline with a simple, match frame, then insert/overwrite. It was an easy way to very quickly replace clips. This is now no longer possible, and has completely ruined my workflow for many big projects.
Please make it possible to match frame both in and out points, I beg you!
