Maximum bit depth-maximum render quality when dynamic linking
Hi
A bit confused by the use of Maximum bit depth and Maximum render quality as used both in Sequence Settings and also as options when rendering in AME.
1 Do you need to explicitly enable these switches in the sequence for best quality or, do you simply need to switch them on in AME when you render in Media Encoder?
2 When dynamic linking to After Effects, when should you use an 8 bit vs 16 or 32 bit working space, and, how does this bit depth interact with the maximum bit depth, maximum render quality in PPro?
