joer92986467
Media Pending, and pending, and pending...
  • August 12, 2019
  • 1914 views
Suddenly its media pending forever. I have looked at many forum post and it seems adobe can't give any straight answers and no real solutions on this but before I cancel my subscription I will see if I can get any help.
Media pending right when I import it and then machine goes into no response mode.
ALienware 15 r2 is the machine. Runs everything. Drivers updated
I see most of the time adobe tries to shift blame to your machine, PLEASE DON"T
Can you help me adobe?
Message was edited by: Buck Sommerkamp [updated title to be more descriptive of OP's issue]
    Correct answer R Neil Haugen
    We're peers, here. This is a user to user forum primarily. Unless someone has a red Adobe badge/avatar we're just users.
    "Media pending" results from something hanging up on the individual computer and I've seen a bunch of things lead to this. So trapping out what's happening on any one machine may be quick or take a few steps.
    It can be a drive/folder permissions problem which might be solved by making sure Premiere runs in Administrative mode.
    It can be a problem with the media cache or cache database files, fixed by closing Premiere and deleting all such files, which can take some hunting.
    It can even be a corrupted project file fixed by creating a new project file, and using the Media Browser to import the sequences of the corrupted project.
    Mozimoch
    Found an alternative solution, aside from your suggested fresh install, apparently there is a new OS for windows update. We just need to update the OS and everything works perfectly again.
    joer92986467
    Sounds good. Let me know if that works for you.
    Mozimoch
    Yup same here. It's been 5 days and I still have not seen any improvements.
    joer92986467
    Fresh install of windows and load adobe first after driver's and updates.
    Mozimoch
    Damn! That's a huge deal of hassle, man! I will try to update my windows first. Can't afford to do such fresh installation. Got a deadline to work on. Thanks for the note!
    R Neil HaugenCorrect answer
    joer92986467
    None of those things helped at all. Anything else I should try
    I can edit video on my phone with no complications but this well-known
    software can't run effectively. This blows my mind!
    Joe
    On Mon, Aug 12, 2019 at 7:10 PM R Neil Haugen <forums_noreply@adobe.com>
    MyerPj
    It does sound like a media / cache problem, deleting the cache folders and firing up PP, would be the first thing I try.
    Using the below shortcut you can delete these three folders, then fire up PP with your project.
    %UserName%\AppData\Roaming\Adobe\Common
