Memory Leaks and Hogging on 2017 iMacPro with Premiere Pro v22 – Solutions and help?
- January 28, 2022
- 1 reply
- 1001 views
I recently upgraded to Monterey 12.0.1 and Premiere Pro 22.1.2. Before upgrades PPro didn’t have memory issues. Now as I start editing in the morning, the memory shown in the Activity Monitor for Premiere starts out fine, maybe 3-7 GB, but within 5 minutes, the memory use starts to increase by leaps and bounds. I can usually keep editing but playback becomes slow, etc. It doesn’t matter what project is open––small or large. Happens with any kind of media.
Memory and Real Memory go way up, even to maximum system GB, and the Swapped Used memory goes crazy sky-high to over a gig, sometimes 3GB! Once or twice, I got the “system out of memory” warning and the system crashes.
As a temp fix to keep editing, I use Clean My Mac and Funter. Clean My Mac doesn’t help much but Funter cleanup gets RAM back down to normal. But running Funter every 20-30 minutes is a hassle. And even after running Funter the whole cycle of increasing memory use starts again.
I’ve tried several solutions: deleting cache, resetting prefs, lowering playback quality, reducing project size and assets, importing projects into new ones, setting new scratch disks… the memory building cycle keeps repeating. I’m attaching screen grabs of my Activity Monitor, taken at the start of an edit session and over the next 40 minutes. Notice the swap memory jump between images three and four!
SPECS:
2017 iMac Pro on Monterey 12.0.1
3 Ghz-10-Core Intel Xeon W, 64 GB DDR4 RAM, Radeon Pro Vega 64 16 GB
Premiere Pro v 22.1.2; Media Encoder and After Effects are all latest versions too
All suggested solutions are greatly appreciated!
