Microphone activated when Premiere is running
  • October 3, 2017
  • 4 replies
  • 32965 views
Since Adobe redirects me to forums as the only means to get support, I'll post this here - even though it requires a response from Adobe.
I've recently started using a software that notifies me once the camera or microphone on my laptop become activated, since I am concerned with how privacy is handled by software companies. I was very surprised to understand that the mere fact of starting Adobe Premiere Pro up activates my microphone immediately and continuously. This means the software has access to the mic audio *simply by running*.
Assuming that this feature is intended so that the user can record audio directly into Premiere, it should only become active once the recording process is actually starting. This is self evident to me.
Skype, for example, activates the microphone only when a call is effectively established (not even when it is ringing), which is how it should be. Adobe is not taking my right to privacy seriously and I request an answer on why this happens and an urgent fix.
Thanks.
My laptop is informing me that Adobe Media Encoder is using my microphone, AND IT'S NOT EVEN RUNNING! WTF, adobe?! Why is Media Encoder using my microphone?!
I highly doubt it is actually using your mic. It would have permission to use it, which of course isn't the same thing. And with any experience of computer apps, between the handshaking between the OS and the various apps & subsystems, something that was listed as 'currently using' a computer resource may no longer be using it, but ... the link showing it as such wasn't officially terminated.
Which is very common.
And with several million daily users, they have no interest whatever in anything you say heard by that mic. And no use for it either. No way to 'capture' even, nor transmit the signal. A big ... nothing.
I've got the same issue. Still no answer from Adobe...spyware? I think so.
No, it's not spyware. Simply that the engineers set it to attach to the microphone on launch, to make sure it's "ready" at any time. Engineers have their own ways of thinking ...
IF it's not spyware, why can't I even hear premiere's audio when I turn off my "microphone access for this device" in windows settings? forcing users to have their microphone on for such basic functionality of the program is not only unfair and doesn't make sense, but it's also compromising my privacy by forcing me to keep the microphone access on for no apparent reason.
I personally can't think of a single reason for this, other than spyware. I am being forced to give microphone access to gain basic, unrelated, functionality that should come as a given
Just put Sophos anti-virus on my Mac. Got note that PP is using the mic (and Lightroom). If I turn "Audio input = none" … nothing changes. I still get the message that Adobe is STILL using my mic. As soon as I have the anti-virus force the mic to "off" … PP freezes and crashes. So… it's either spyware … or no PP? Something's odd. Either anti-virus has it wrong, or "using mic" is not what I think" or I just don't know.
Under Edit>Preferences>Audio Hardware... change Default Input to No Input.
Odd.
I'm afraid the only other advice I can think to offer is not to run Premiere Pro on a Laptop.  The ideal starting point for editing is multiple internal hard drives and a 24" 1080p screen, which no Laptop in the world offers.
Build your own Windows machine.
Sorry I couldn't be more helpful than that.
