missing tools in tools panel
  • May 14, 2017
  • 7 replies
  • 25211 views
Suddenly I am missing some tools in my Tools panel. Regardless the choosen workspace. See picture. Where can I find the missing ones?
Correct answer Meg The Dog
If the tool has a small triangle at the lower right, then click on the tool and hold down to reveal more tools:
MtD
I've had same problem.
One solution I've found is reset workspace to 'editing' ; i.e window/workspaces/editing.
Good luck
Try opening premiere in full screen, then all the tools re appear
Has it been resolved? That tools also dissapeared for me and I cannot find it. I need to use razor tool but it just dissapeared. Is there a window that I can check to see them again or how can I get them
Nevermind I confused premiere pro with after effect lol
lambiloon
Only editing option you have choose that then all will be good...thanks
Ali Sajjad / Graphic Design Trainer / Freelancer / Adobe Certified Professional
Becky89
Mate, you misunderstood. I am able to find effects panel. But in effects panel there is no transform option, Crop option, Track matte option. Am I explained it clear? So, I see effects panel, all good. But cannot find lots of effects. They are gone.
lambiloon
then try to uninstall it using creative cloud remove tool and install fresh one its all ok at my side i checked...thanks
Becky89
Hey guys, pls help. I don't have default tools in my premiere? for instance, Crop tool, transform, track matte key, dissolve types etc. I am exploring internet already a week but did not find an answer. I tried to clear cache, to unchecking boxes etc.
lambiloon
Hi in windows then workspace choose default editing then all tools will be there...thanks
Becky89
I dont have default editing option in windows -> workspaces. Adobe Premiere Pro CC 2018. I even installed and uninstalled already 3 version of Premiere
THANKS. do you know of a way to stop this bloody gpu render issue!?!?!?!?!? its been over a year and adobe are NOT addressing the issue. for some of us this is our livelihood........and why does playback keep blacking out too
Thanks guys but I hink I mis-expressed it. The entire panel keeps disappearing  with all the tools in in one go. I'm about to eat my underwear out of frustration!
Go to window/workspace/reset to saved layout a couple of times.
Meg The DogCorrect answer
MtD
so where is zoom? why arnt the tools laid out like in every other video.....i thought updates was meant to make life easier.......cc is a ball ache not to mention the render issues that still havent been sorted a year on
Zoom is behind the Hand tool.
