MOGRT Properties Panel does not work; impossible to use media replacement
Hello everyone. I'm experiencing a problem: none of the MOGRTs can be controlled through the Properties panel. While I can manage them via the Effects controls, I am unable to replace the media since the Properties panel lacks any controls for the MOGRTs. This feels like a bug to me; everything was working fine a few months ago.
astrid_7334Correct answer
Had the same problem. If you deselect that part in your timeline and use alt + select (windows) that part again, it did work. Hope this helps 🙂
This is driving me nuts. I have been using transition MOGRTS for years why has this become a problem? I am in the properties window it is unusable. I have an older version of Prem pro, which I keep becasue of Raptor  but I cant  back on this project.
If you're trying to open it on the timeline, it doesn't work. I always have to select a random video in my finder (with the 'replace from finder' and then I can select 'open in timeline' and remove the placeholder and put in whatever videofragment I want. Hope this helps you out 🙂
alexgigned
Wow, that works! Thank you.
Annoying bug
Stan Jones
@Arseny34633155hcue,
You have to select the layer in the Properties panel. I'd like an option for a single layer graphic instance to start with that layer selected.
This is true for PR created mogrts.
AE created, with restricted parameters, open as previously - with just the properties that are allowed to be edited.
@Jarle Leirpoll,
Any way around this?
Stan
Thanks, but that did not help for me
Have you tried resetting your preferences? After the app launches, you can reset it using the Reset button in the Preference Panel. The app needs to be restarted to reset. To restore default preference settings and plug-in cache simultaneously, press hold Shift-Alt (Windows) or Shift-Option (macOS) while the application starts.
