Oct 28, 2021 4:49 PM UTC
Motion Graphics PROBLEM and Premiere Pro 2022 keep crashing.
Recently updated my Premiere Pro to 2022, and it's just ridiculous. I can't even work as it keep crashing. Motion Graphics stuck at 15%, then I have to force quit the program. Then Motion Graphics media always pending. I want to downgrade but how? The new update just sucks.
ryanmuirCorrect answer
Nov 5, 2021 12:49 PM UTC
Nov 2, 2021 11:21 PM UTC
Same here. I've noticed when you click "link media" it gives the wrong base file path, and selecting a new one to link gives the spinning ball of death. Definitely an Adobe error, and not user created.
Adobe 2022 on M1 Max.
Nov 2, 2021 6:49 PM UTC
Also having to downgrade to 2021. I'm on macOS 11.6.1 on an iMac 27" with 64GB.
Nov 2, 2021 6:20 PM UTC
I'm having the same issue, but only with certain motion graphics that are bigger (1.5 Mb and 16 MB, the rest are like 100-800 KB).
Oct 31, 2021 7:33 PM UTC
Omg, same. SMH. I have a project that has to be done by Friday. Guess I'm going figure out how to get my AE files to be usable in Final Cut Pro. Sucks because I'm not proficient in it. I've tried everything I can think of in Premiere to make work. Please, Adobe, we love you but you could potentially cost some of us some jobs. Make sure it works first. Think I'll make sure my auto updates are turned off for next go round.
premier setup
Nov 2, 2021 2:08 AM UTC
Same project, tried Adobe support and they have no idea how to fix it. More so the person trying to help had very little knowledge of tje program. It os so frustrating, Ive had no sleep for the past 5 days dealing with nthis.
MyerPj
Oct 30, 2021 6:20 PM UTC
It would be nice if even just one person said if it was mac or pc, which os, what hardware, etc...
Oct 30, 2021 7:04 PM UTC
Why should this matter.  This is such BS.  We go through this crap almost every update cycle.  Please for the love of God Adobe start testing stuff before you release it.  I am in the same boat -- the one that is sinking.
Mike7385
Oct 30, 2021 7:08 PM UTC
Yup
Mike7385
Oct 30, 2021 5:47 PM UTC
I have never been more motivated to suffer through the learning curve of learning Davinci than I am now. I hate what Adobe has become.
Nov 3, 2021 9:21 PM UTC
I work in both PrPro and Resolve. BM just released a major update, 17.4. Which exactly like the Pr 2022 release, has most users doing fine. Some have irritating issues. And some are completely bonked in the new release. They even put out a patch that one noted colorist posted on the BM forums was worse than the original build on his machine.
But again, many users are doing fine in the newest Resolve.
No colorist I know updates to a new version of Resolve until they've tested it on a secondary machine and know that for their media, kit, and workflows it's stable. Solid.
Why you wouldn't do that with any program, I don't know. I've used computers for well over 30 years. Long ago I learned to never ever trust a new build with client work.
It's actually easier to test a new major version in Adobe products than in Resolve. You can have mulitple major versions installed with the Adobe products, you can't with Resolve. And with their heavy database structure going backwards is also a bit of a pain. And you have to uninstall the 'newer' version, reinstall the older and do some work to get back to work.
Or ... with the Adobe apps ... simply install the new version. Keep working in the old while testing the new. When the new is stable, migrate projects into the new version.
I'm staying with Resolve 17.3 for a bit yet personally.
Oct 29, 2021 9:36 PM UTC
I'm Alo having the same issue, but with After Effects files in Premiere.
Jeffthomas
Oct 29, 2021 9:48 PM UTC
Also having the issue with an after effects file placed in premier pro. Says media pending and then freezes up the program and I have to force quit. Very frustrating
Oct 29, 2021 9:29 PM UTC
Same issue. I can't even export XMLs to try to salvage some of my work. Looks like some folks at adobe are going to have a busy weekend...
Mike7385
Oct 30, 2021 5:50 PM UTC
You'd think they would, but I don't think they actually care about their customers. They use all of us as testers and continue to take our monthly subscription while doing the bare minimum.
Creative Cloud users should get an apology e-mail with an ETA on when this will be fixed.
It's the least we deserve.
Nov 16, 2021 2:37 AM UTC
And a free month or as long as it takes to get things working the way they were before the upgrade!
Oct 29, 2021 5:35 PM UTC
Also have this issue. What I also noticed is that when opening an project, every motion I have in the project won't load, it'll say "media pending". Left it loading for hours, with no change at all.
Unfortunately, I'm having to downgrade.
Oct 29, 2021 5:39 PM UTC
Yep, I had to downgrade for it to work.
Oct 29, 2021 8:48 PM UTC
Unfortunately, even after downgrading, I'm left with a couple of issues, which I'm not entirely sure where it stems from, perhaps some leftover files? Not sure, will continue to investigate and see if I can figure out what is going on.
Oct 29, 2021 5:19 PM UTC
I am having the same issue.
