Motion track and replace screen in Premiere Pro CC without After Effects or Mocha
  • November 9, 2018
  • 3472 views
Hi All!
I work at a post facility that has been Avid since it's start. We are currently having our staff learn premiere pro as well to expand what we can offer.
Several of us, including the instructor for premiere, have been trying to find a way to do motion tracking and screen replacement within premiere pro without having to switch over to AE. For example, the corner pin tool seems almost useless since it can't seem to track the layer below.
I realize PP really pushes for people to use AE for motion graphics. However, PP seems to have some decent tracking tools, and for something like a rough screen replacement, is there any way to use those tracking tools in PP without needing to rely on AE?
Thank you!
Correct answer premieregal
I'm afraid there is no easy to do this in Premiere Pro. But Premiere Pro does work with Mocha. I have a tutorial here on how to do this:  How to Track and Replace a Phone Screen with Mocha Pro in Adobe Premiere Pro - YouTube
Right now we're offering a 30-day *watermark free" trial of Mocha and all BorisFX plugins if you want to try it out, Go to the BorisFX store (http://bit.ly/GalBorisFXStore) and then choose host as "Multihost" and purchase options as "30 day subscription".  Add to cart and checkout using the coupon code "premieregal". Licenses and installing instructions will be emailed. The coupon code expires on 11/30/18.
premieregal
premieregalCommunity ExpertCorrect answer
