Moving the audio less than a frame in Premiere Pro cs6
My video and audio is just a tiny bit out of sync, but regardless of what I do I don't seam to be able to move the audio less than a frame. I was able to change the mark in point less than a frame, but when I drag the audio in to the project it always lands in the same spot. What should I do? It doesn't seam to be possible to turn of the time units once the audio is imported. I've already edited the video quite a lot, so I don't want to import the video again.
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from Premiere Pro NEW to Premiere Pro OLD... Mod]
