Multi-cam audio tracks like video tracks?
  • April 30, 2025
  • 274 views
Hi there, I am sure way back in the day I was able to enable multi-cam and switch between Camera 1,2,3, etc. AND independently be able to switch between Audio Track 1, 2, 3, etc.).  It's very possible I'm crazy, but I am sure I was able to switch between audio just like video, but I only have [1] as the audio option.
I know there are ways to get all audio tracks from the multi-cam sequence into the new sequence, but I can't keep them linked and so when there are multiple different interviews, getting out of sync is very easy.
I'm going through the premierepro.net multi-cam page now, so I might figure it out.  But if you know what I'm talking about, I sure would appreciate some input.
Thanks!
Correct answer Stephen.Pickering
Hi Kevin, I believe we found that you can only select different audio tracks IF you ALSO have multiple video tracks.  So, adding an additional video track (even if it's empty) in the nested/layered video then allowed us to select different audio tracks.
Kevin-Monahan
Hi Stephen,
Thanks for the message. Please let me know if this discussion answers your question: https://adobe.ly/4jVb51D
Let me know if it does.
Cheers,
Stephen.PickeringAuthorCorrect answer
