DJP2014
Multi-Cam Preview Monitor doesn't scale footage properly
Several people have posted about this problem, but for years nothing seems to have been done, so I'm adding it as a bug.
4K Multi-Cam clips appear zoomed in when working in a HD sequence. 4K>HD is a common workflow, not an edge case, and therefore this should be fixed. Resizing hundreds of multi-cam clips isn't a solution.
R Neil HaugenCorrect answer
Thanks for the clarification ... I wasn't sure if you meant program monitor or source monitor. Like Resolve, for some things Premiere hath its own terminology.
And yes, the Source monitor is "pre" things applied in Sequences. But the "multicam" is sort of a clip in some ways in Premiere, sort of a sequence in others. Which can be durn confusing at times.
DJP2014
DJP2014Author
I believe what you're describing is what Premiere is doing currently. Which is wrong. The Preview Monitor's purpose is to preview what's inside the Multi-Cam, without the timeline having any effect over it.
Bruce Bullis
Confirming desired behavior: When you nest a multicam, you want PPro to scale all the cameras within that multicam, based on the settings of the sequence containing the multicam sequence?
DJP2014
DJP2014Author
Hi again Bruce - sorry, I keep running in to bugs today, so having a bit of a rant 😉
I'm aware it's possible to resize a 4K Multi-Cam sequence down to HD, setting each layer to 'Set to Frame Size'. It's a fine workaround if the project only contains a few sequences, but I have hundreds. This has been an issue for years & years, I think it should be fixed.
Dan
Bruce Bullis
Are you making use of either 'scale to frame size', or 'fit to frame size'?
https://premierepro.net/scale-frame-size-vs-fit-frame-size/
