MultiCam Audio - Flatten (Disappearing Audio)
  • October 19, 2020
  • 11 replies
  • 6668 views
Is there a bug with multicam audio when you flatten it? It makes my audio file disappear from the timeline!
this is still an issue in 2024.
but making sure there was a camera on track V1 worked for a project I am editing today. I get this issue a lot, so will be interesting to see if that always fixes it.
The only way I've found to combat this is using (not sponsored plug here) The Knights of The Editing Table's Grave Robber plugin. It manages to figure out what Adobe can't when it comes to this bug...
peidshjt
Audio is no longer disappearing... however, they broke it in so many more ways
_Spliced
Another workaround is using Grave Robber to 'un-nest' the multicam audio, this worked much better for me.
https://knightsoftheeditingtable.com/grave-robber
bb42
Woah! That's really useful in many ways (but also shouldn't be a problem that requires it in a first place and that functionality should be part of premiere) - but anyhow, thanks for the recommendation!
I had the same thing happen, but just realized what the problem was for me at least.  Hopefully this will help somebody else.
For me, the problem was a result of mismatched audio.  In my case, my multicam sequence's audio was single track stereo. However, in the sequence in which the multicam clip was nested, it was somehow labeled as mono.  When I tried flattening it, it disappeared.
To rectify this, I right clicked on the offending clip, clicked 'Audio Channels,' and made sure the audio wasn't mono audio.  You can tell it's mono if only the very first box in the matrix is checked.  To make it stereo, I click box [2,2] in the matrix and voila, the waveform turned stereo.
Upon flattening the multicam, it worked beautifully.
Here's another workaround that actually worked for me:
1) Make sure the button for "Insert and Overwite Sequences as Nests or Individual Clips" is set to invidivual clips (should be white, not blue).
2) Position playhead at first frame of your multiclip, select audio so its highlighted
3) Squence> Match Frame (F Key) - This will open the clip in the Source window
4) Drag the audio from the source window to your timeline, replacing your clip with all the audio files within the multiclip
peidshjt
It's a bug and it's been happening for so so long
Ive called into support many many times over 7 years on this issue, and I've gotten everything from "we'll work on it" to "this is by design"
it's not by design, the video would disappear in that case, and also, the audio wouldn't playback inside the MC if this were design
I'm currently trying to climb the support tiers now and not having much luck...
EuanP
So frustrating that this still hasn't been resolved. I've run into an issue whereby multicam clips aren't respecting channel designations, and are laying Ch2 of the multicam clip into both Ch1 and Ch2 of the timeline. The solution up to now has been to flatten them, causing Ch1 and Ch2 to appear correctly. However I've now run into this disappearing audio issue....
A Year later and this is yet to be resolved!
I'm working on 15 multicams each with 4 cameras/layers of video. The only one with more than a single clip per layer, won't flatten.
Not sure if this will help, but I ran into a similar issue where if I flattened all the clips, if I had a cut on the audio timeline, the first section would convert properly, but anything later in the audio timeline wouldn't flatten.  I had to first "enable" each of those secondary audio clips, once I did this, then selected everything in the timeline, all the clips and all the audio flattened and I was able to export an XML file that I could import properly into Resolve.
Yes, there's still a bug in the latest version, 15.4.
Flatten audio that is in a multicam, and the multicam dissapears.
This is a big issue, because we have to flatten the audio before exporting an OMF. If we don't, the clips aren't trimmed and copied into the OMF.
I'm having this issue. have you found a solution??
bb42
It's June 2021. This problem still exists in the most recent Premiere 15.0
If you have mutliple clips inside of a multicam clip, attempting to flatten that in the edit timeline results in all the audio associated to disappear.
This doesn't happen if there's one clip in a multicam. Only if there are multiple ones.
JUNE 2022 AND STILL HASN'T BEEN FIXED. Absolutely incredible what that $60 a month gets you @adobe
Yes i also noticed this. When you have several clips on a track (in the multicam clip), then if you flatten, the audio disappears. If you cut to an angle that contains only 1 continuous clip it doesn't happen.
peidshjt
Yep... if the camera ever cuts and continues running within the same multicam, video is fine, audio disappears after the first clip per track
