My card is NVIDIA GeForce GTX 260 should be a problem running Premiere Pro cc 2018 12.1.2
  • March 10, 2020
  • 3354 views
Adobe Premiere Pro System Requirements
System requirements | July 2018 (12.1.2) release of Premiere Pro CC 2018
My system 4GB/Xeon/Win10pro, can Not run Premiere Pro cc 2018 since the minimum is 8GB RAM
After changing RAM to 32GB DDR2 hope run it,  I already ordered RAM from eBay
As Adobe says Optional: Adobe-recommended GPU card for GPU-accelerated performance
// My card is NVIDIA GeForce GTX 260 should be a problem running Premiere Pro cc 2018 12.1.2... What you think???
Recommended AMD and NVIDIA video adapters for GPU acceleration
WINDOWS CUDA
NVIDIA Quadro GV100
NVIDIA Quadro P6000
NVIDIA Quadro P5000
NVIDIA Quadro P4000
NVIDIA Quadro P2000
NVIDIA GeForce GTX TITAN V
NVIDIA GeForce GTX 1080 Ti
NVIDIA GeForce TITAN Xp
NVIDIA GeForce GT 750M
NVIDIA GeForce GT 755M
NVIDIA GeForce GTX 675MX
NVIDIA GeForce GTX 680MX
NVIDIA GeForce GTX 690
NVIDIA GeForce GTX 770
NVIDIA GeForce GTX 775M
NVIDIA GeForce GTX 780
NVIDIA GeForce GTX 780M
    As for this original question, your GPU is already long obsolete. In fact, it became obsolete before Premiere Pro CC 2018 was released. You see, Nvidia had already ended support for all Tesla-architecture GPUs, including the entire GeForce 200 series, back in 2015. Accordingly, beginning with Premiere Pro CC 2015.3 (released in the Fall of that year), Adobe now requires graphics drivers that no longer support legacy or obsolete hardware in order to even use GPU acceleration at all. At the time of CC 2015.3's release, the GeForce 200 series was already in the legacy support phase. Thus, since the very last security-patched driver was released in December 2016, the GeForce 200 series was already obsolete by the time CC 2017.1 was released.
    lsepolisAuthor
    I will try the below... is it the same for Premiere pro cs 5...? Yes same / No differs
    Windows, for CS6, the "cuda_supported_cards.txt" file ...
    Also note that as upgraded to Win 10 from 7
    Stopped working the CS 5 Premiere pro in Windows 10
    This is one of 5-6 PCs in my photography lab and, in the lab needed this run Premiere  pro nevertheless running also newer versions in other PCs... i have connected legacy hardware in this referred old workstation PC...
    lsepolisAuthor
    Premiere Pro CS 5 -  the "cuda_supported_cards.txt" file  has the line:
    "GeForce GTX 260"
    already and Not opens, anything else to try...?
    lsepolisAuthor
    Premiere Pro cc 2018 Not open // go to splash-screen and freezes
    But Photoshop cc 2018 Work OK
    Tried
    https://www.youtube.com/watch?v=rQm8Jlr8iwQ
    Product: HP Xw6600 Workstation / XEON E5405 / 26GB RAM DDR2
    Operating System: Microsoft Windows 10 (64-Bit) Pro
    NVIDIA GTX 260 Graphics Card
    but my settings are somehow different from the video solution--- what settings choose for Premiere Pro cc 2018 in NVIDIA Panel 3D...?
    The GTX260 wont run with 2018.
    The gpu card needs at least 1 gig of vram which it does not have.
    lsepolisAuthor
    Photoshop cc 2018 working because needs less VRAM?
    Also if upgrade Graphics card [can you tell URLs min compatible Card for my old PC?] to eg 2GB or more VRAM should work? May due old PC get a used card
    Also, this PC has and older CS 5.5 Premiere Pro - what settings choose for this???
