My sequence is not showing up in timeline
  • March 5, 2021
  • 6 replies
  • 42984 views
Reaching out to the experts here.
So i created my first video in Premiere Pro and I posted it to YouTube under private so my friends could see it and give feedback before publishing. However I notice that two frames in the video gave an error message indicating that when i created the final video that i'd somehow deleted the original source of the video clip.  I figured easy, so i just go back into premiere pro and re-open my project and put the missing file back in the video and re export.
However when the project opens in premiere pro all my library of images and video clips are in the left hand box but nothing shows in my timeline so I can insert or edit etc.   I have searched and tried dozens of ways to find it but come up blank.  I really dont want to go back and re create the video unless I have to. I sense its a simple route directory, source setting i'm missing or havent clicked.... but i'll be damned if i can find it.
Anyone experienced this before?
Mark
Can you Dropbox a copy of your project, without the media, so we can have a look.
falcnrAuthor
Hi Richard,
It appears my sequence is missing entirely within the single project i'm working on.
i'm going to start a new project and see how this goes.  My first attempt to do this wasnt great as when i tried to import the 3 random videos into the timeline it wouldnt allow it.  Apreciate your assistence
Mark
To support this assumption, I tried to make a second video and randomly picked 3 videos and put them in my project folder. I then tried to drag into my timeline and they wont go. I get that hand grabbing logo but when it enters the timeline it has a "no entry" symbol.
That is a different user error.
I think you have under estimated the software: especially if your are new to video editing.
The software is targeted towards Professionals and advanced hobbyists.
Premiere has a steep learning curve, not something you master in 7 days.
Even after using the software for 20 years I learn something new every so often.
You can master the software but it will take a little bit more of your time.
Guessing you sequence is gone. Might want to look into the auto save folder for a project that might still have the sequence.
You need to have the project panel open:
In my example the project is called book day.
falcnrAuthor
Any idea why this "automate sequence" is greyed out in the project folder and can't be activated?
Because you have not setup the clips for automate to sequence.
Why not try a fix your orignal problem first.
Set Project window to List View: second icon on the left.
Now look for this icon
There are no "dumb" questions, so please ... ask away! This is a complex and complicated app, and after a number of years of hours a day, I still find things I'd had no clue about. As does everyone I know.
That screen you're showing ... see where it says "Source" at the top? That is the Source Monitor. You need the Project panel, at first often found among those in that "panel group" in the lower left corner of that image. There are other panels to the left or right of those showing.
In your first image, here?
Look at the top right corner of the area with the blue 'active panel' border. It says "Project". That is the name of the panel, and it is one of several panels in that blue outlined area or "panel group".
So it's in that Project panel that you will find your sequence, with the icon that is shown in Gerik's post.
gerikp
Here's what a sequence icon looks like when you are in an icon view in the Project panel. Sorry, the example I sent you was in list view.
falcnrAuthor
Hey Gerik,
As mentioned to Neil. I am of the understanding I am in the project Bin ... does it look like it to you in this image? If so, no such icon for the sequence is evident in my images or videos.
Am I skipping something obvious ?
thx
Mark
Gerik was talking about the Project panel, on the left of your image. His was simply displayed in List view, yours is displayed in Thumbnail view.
Scroll down through the project panel, and find where there is a thumb with that icon on it that his pic points to. That is your sequence, typically named identically to the first clip dropped on it. Which is confusing.
And why many of us immediately rename clips when creating them. Sequences named for clips in the same bin is confusing.
(Oh, and this forum's software is silly at best. Please drag/drop images directly onto your text reply area so we don't have to download strange files to see them.)
falcnrAuthor
Hi Neil,
thanks for the fast response. Sorry for dumb questions. In assembly you get the image I previously sent but when I see the Project Panel shown in the editing page has nothing resembling this "sequence". Am I missing something ? Is it in a sub menu ?
falcnrAuthor
Hi Gerikp
Here is a screenshot image and nothing in timeline or any icon etc to click onto.  Please note I'm just getting into video editing and this is my first video i've edited on PR so i'm still navigating through it all.
Thanks for your help though. I sure hope I don't have to re make the video and it really is only a matter of finding it behind some curtain.
gerikp
Your sequence is probably hiding out in your project bin amongst your clips and such. Look for the Sequence icon That has a bunch of horizontal lines that are blue and green. Double click it to open it up in your timeline. I've attached a screenshot for reference.
