My voice over is doing an echo??
  • July 9, 2023
  • 2521 views
Hi. I am using Premiere Pro to edit some videos. I added voice over to the beginning of my video and it worked fine. But I am trying to add some to the middle and it is doing a weird echo sound. Does anyone know why it is echoing? Im sure it is a simple fix but I just don't know what it is. Thanks!
The echo issue might be due to multiple audio tracks overlapping or an effect being applied inadvertently. Check your audio track settings and effects to ensure no extra effects are causing the echo.
For a quick fix, you can watch this https://www.youtube.com/watch?v=joWiXSTdjo0
What if we we don't have the option to adjust preferences? I've included a photo of what my edit tab looks like:
Averdahl
On Mac, go to Premiere Pro > Preferences.
Peru Bob
Thank you. I figured out how to fix the echo but I have another question.
For some reason, I can hear sound from my video over the music I have
added. How can I stop that from happening? I can also hear the sound from
my video over the voice over I added. Im not sure how to fix that.
Try using the track mixer to change the levels.
