Mysterious quality drop after exporting
  • February 16, 2017
  • 1270 views
Hello, I'm a bit of an amateur when it comes to video editing and I could use some help. I recently created a montage from video game recorded from my PC. I use Nvidia Shadowplay to record a monitor capture at 1280x720, 60 fps, at 50mbps bit rate. My sequence settings on Premiere match this and everything looks great in the preview. I render and export using H.264, preset settings are for Youtube 720pHD, profile is set to high with level 4.2, and I have the encoding set for 2 passes with a target bit rate of 60. Everything I've read from guides tells me that my videos should be coming out of the export looking pretty good, but I'm noticing a very clear drop in quality that I can't seem to find an explanation to.
I use an effects pack for some touch ups and transitions during the video, and I considered if they would be the cause of the problem because the effects themselves are in a 4k resolution. Scaling them down to match the 1280x720 video didn't help the quality, and neither did removing them entirely. Without the effects I then tried exporting at the highest possible settings, 300 bitrate, etc, and I'm still not seeing any increase in quality.
I don't understand if I'm doing something wrong or if there's simply some setting I overlooked, but any help with this would be appreciated.
Here is the video in question that I'm experiencing issues with. At 2:21 you can clearly see what looks like the video suffering from a low bitrate: ULTRANUMB | A Rocket League Montage - YouTube
    Looks fine to me:
    On a side note dont watch on a 1080 screen but set it to 720.
    Post screenshot of export settings with left tab to output and with an image.
    Here you go: Imgur: The most awesome images on the Internet
    Around the same time as the preview image is when I'm noticing what looks like a low bitrate on the video. To me it definitely looks sharper in the preview than it does after exporting. I don't fully understand what you mean by not watching on a 1080 screen, though.
    Your capture is only 720p if you blow the image up to watch it in a 1080 screen you will see degrading.
