Need a script or extension coded for Premiere Pro to make cuts at times, or maybe automation blocks?
I need the ability paste timecodes into a text box such as:
00:13 - 00:23
00:25 - 00:33
00:43 - 00:48
and then I need PPro to make a cut at each point of the current timeline, and then to use one colour to label the new cuts in the timeline.
Is this possible? Where do I find a tool that can possibly do this already, or where can I find a dev ask what it would cost? I researched the new UXP Dev Tools to try and vibe code it myself but realize that an interface isn't possible with UXP. I'm not sure how extensions work or are coded, perhaps that's what is needed.
