Mar 16, 2025 8:18 PM UTC
Need advice on what capture card or device I need
I have an older DSR-11 that I want to use with Premeire to capture digital video and a brand new hot shot computer. The DSR-11 uses an ie1394 firewire connection and my new computer doesnt have that port or card. Can anyone suggest an external card of some sort? I really don"t want to crack this pc open again. Thanks.
John T Smith
Mar 17, 2025 2:54 PM UTC
What I used with some old VHS tapes is http://www.scenalyzer.com/ and it works well, do change the default Fat32 to NTFS setting to not have lots of 4gig files
-I have NOT used the scene detect function in scenalyzer, so don't know how well it works
The last time I converted Analog to Digital (VHS tapes from an EARLY camera) I used an external Grass Valley ADVC 110 (no longer made) to do the conversion and then send the signal to my computer via Firewire cable
JonesVid
Mar 17, 2025 1:05 PM UTC
I have same task to import lots of DV/HDV tapes - I bought myself a Firewire PCIe Express card off Amazon. Not expensive.
I think Windows 10 recognises it straight away.
Ann Bens is correct that Windows 10 is best, it lists Sony /Generic options I think.
I just had a look on my Windows 10 back up PC with Creative Cloud and the last Premiere Pro version supporting Firewire Capture is 2023 version - hence a problem..... as Adobe only supports last 2 releases unless you already have it on your machine historically.
There are external convertor /adaptors about to go from Firewire to Thunderbolt 4 interface but never used one, hence I think you are going to have to open up the PC again if you have a spare PCIe express slot.
I tried out the HDV split program that Peru Bob mentions and this also works OK.
This is a very old utility and has no support of course.
John T Smith
Mar 17, 2025 1:38 AM UTC
I have read in the past about devices-and-programs that will connect to a USB port... with the VERY large drawback being that due to the low transfer rate of USB the external devices compress the video so much that editing is a problem
I think you are going to have to buy a firewire card to put inside your computer
Peru Bob
Mar 16, 2025 11:16 PM UTC
Premiere Pro no longer has capture.
You can use these free programs for capture:
WinDV   WinDV
HDVSplit   HDVSplit 0.77 beta
John T Smith
Mar 16, 2025 9:35 PM UTC
I'm not 100% sure, but I don't think the current verion of PPro has firewire capture... have you checked the program to find out if it still has that function?
film842Author
Mar 16, 2025 11:07 PM UTC
No I haven't. If that's true, i wonder where that leaves me. I have an awful lot of mini DV tapes that I would like to digitize.
Mar 17, 2025 10:59 AM UTC
Find yourself an older computer with firewire and windows 10 (not 11)
W11 does support FireWire but might not recognize the DSR-11.
You can try this software also: http://www.scenalyzer.com/
