Need help fixing awful Audio tracks -- noise reduction, filling missing audio tracks, etc.
  • December 15, 2017
  • 331 views
Hey guys!
I am working on a segment piece about a Tech Expo, and the camera guy obviously had no idea about AUDIO! There are so many problems where the talent is not heard well because there is either ambient noise that he competes with, or only one side was recorded (right side audio, yes; left side audio, none). Anybody have a suggestion to fix this in premiere pro with Audio Effects? Or is there any other step I can take to go about this?!
Correct answer excited_Genie16B8
You can use the Fill effects to center the audio.
Applying effects to audio in Premiere Pro
Adobe Premiere Pro Learn & Support
On the ambience issue, you're probably hosed.
excited_Genie16B8Correct answer
chrisw44157881
can you post a 10 sec example? if you have audition, I suggest that forum as well as there are some helpful people there too.
