Need help with custom script for Automation Blocks
Hi!
I need to create a script that replaces a clip on a sequence, adjusts its size to fit the frame and also changes a couple things on a mogrt.
Would anyone be able to hop on a call to help create that kind of script? It could be a paid collab if needed.
Thanks!
Mathias Moehl
Mathias MoehlCorrect answer
Hi Albert,
to scale clips to fit the frame, we have the sample script "Selected Clips - Set Scale to Fit or Fill Frame Size" in the Automation Blocks library. For updating mogrts, see
https://docs.mamoworld.com/automation-blocks/tools-pr/templateTools
For paid help, I recommend to ask TMMW, see:
https://docs.mamoworld.com/automation-blocks/hireAnExpert
Mathias Moehl
Hi Albert,
Hi Albert,
Thanks for the question and welcome to the forum. You have marked the post with the SDK tag. By doing that, you'll be calling an Adobe Expert to the post. I hope they will arrive shortly. Sorry for the frustration.
