kevink34003390
No Audio after export
  • October 15, 2017
  • 4 replies
  • 9311 views
I just created a short video in premiere pro, on my timeline everything works perfectly: Audio and video. When I export, there is no audio. I am trying to export H.264, export settings shown below. I see that is is a somewhat common problem but I don't see anything that has fixed my problem yet. I appreciate any help.
Thank You!
Correct answer Ann Bens
Set audio to AAC and try again.
I've been struggling with this for weeks! But finally found a solution. Unistall premiere and install an old version. I used 14.9 and BOOM exported perfectly with regular default settings! Sometimes when things aren't broken, dont fix it. Updating was the problem.
Same issue exporting GoPro 4K Hero 9 footage recorded using H265 codec on Hero 9.
Timeline has mutiple video and audio tracks. The audio plays fine on the timeline. No sound is missing.
The exported file is missing some audio at certain places.
If you do anther export, the audio re-appears in places it was missing but disappears on places where the original export had audio.
This happens in version 15.1 and v15.4.
Reverted to Version 14.7 and v14.9 and the exported file works fine with no missing audio.
So, looks a bug in version 15.x
How do you simply revert to a previous version?
I seem to be having the same exact issue as you described. Audio was all fine in the editor. Once exported, random pieces of audio was missing. Tried re-exporting, and the missing pieces were in other places.
I'm having the same issue with the 2018 update. If my project is more than a minute or two, it seems to have audio missing randomly out of the finished product. Any help or solutions?
this is a longshot, but did you find any solution to your problem? just made a post about something that sounds similar
Did anybody find solution for this? i read all the threads and im exporting audio in AAC and the video keeps exporting with no audio, tried to unlink all the audios from video, tried to export only the audio. Nothing works! please help!
MPEG-1 Layer 1 is a reeeeealy old format.  It's possible your media player just can't play it.
I would agree with Ann.  Leave the default audio options in place.
kevink34003390
Is AAC defualt? What are the other default options? If I changed anything, it was not on purpose.
How do you do that?
