maxleonardfarrell
No Audio On Export [Premiere Pro CC 2018]
  • January 26, 2018
  • 10 replies
  • 105251 views
In my latest project audio has simply stopped exporting. In project it's fine and plays back perfectly but any attempt to export, results in no audio.
I've attempted re encoding and re importing the audio clip as a wav but to no avail.
Additionally the resulting clips all have the correct length. But they just have no audio when played back.
Correct answer Richard M Knight
There is an issue in that if you rate stretch a large amount the export is mute, the work around is to rate stretch a smaller amount, nest the clip and then rate stretch the nest.
Audio works in preview, but not when i render the video
I was also facing the same issue, what I did is "UNLINK" video and audio (external microphone). It worked.
FIXED! I had the same exact problem, but I thought it was because I updated PP recently (03/22) in the middle of a project, but I see that this issue has been around a long time. After reading all the solutions, and trying most of them, it still didn't work. When I exported, there was no audio no matter what media player I used. So using a combo of ideas here, I went and started a new project, and loaded my "silent" cut into it. Guess what? There was sound on the preview! So I crossed my fingers and did an export... YUP!! Got my sound back! I don't know if audio or video degrades after all that flip flopping back and forth, but at least I don't have to start from scratch. Give it a try and let us know if this works for you also.
2022 still have the problem...What happens?
Markd_Arts
I fixed this issue by unlinking audio to all my clips, I had different sources linked together. Cant say that is everyone's issue though. Just try to unlink and see if that helps.
I think I've found the real reason for the bug. It's in video/audio codecs. When I try to export my projects in MPEG2 while using resampling - it exports with no sound. When I leave all export audio options by default - oh, miracle, here comes my sound back. I hope my efforts of wasting my half a night would help someone
This has been the bane of my existence on my last few projects. Should not be a bug and should just be fixed by Adobe. My workaround is to render audio separately as a .wav and sync with the rendered visual. But even if I do this in a new sequence in the SAME project, the audio doesn't render again. I actually have to create a fresh new project and import the rendered assets, create a new sequence and sync together, to finally get my video and audio to output. Ridiculous.
I have the same issue with Premiere Pro CC 2020, how can this issue still be a problem in the latest version? We pay a lot of money every month for using Adobe products and this issue is now almost a year old?!?! How can that be?
marshallw79210903
have the same issue out of the blue in CC 2020. Same project has been exported successfully before, but when I cut a smaller 4 min portion out and did some volume fade on either end to make it smooth, it continually exports no audio. I've created a new project, a new sequence, I'm duplicated the source material and reimported it. nothing works. This seems like a massive issue that should be easy for them to fix, but here we are 2 years after this thread was created still having the same issue with no fix in sight!!!!!!
nicklear
Hit this bug today, arrgh, overnight render failed. Thanks for posting a workaround.
I'm having the same issue on a feature documentary. The workaround is very time consuming and provides a host of other issues. Adobe, can you fix this?
maxleonardfarrell
Okay so it's an issue with the effects, if I export with an audio clip with no effects it will export just fine.
Can anyone advise if I should close this issue and open a new one or just leave this one open?
Just continue in this thread.
This is not a solution, it's a workaround. Any fixes to this rate stretch issue Adobe?
kulpreet singh
Hi maxleonardfarrell,
I am sorry that you are facing trouble exporting your sequence from Premiere Pro.
Please make sure that you have selected Export Audio in the Export Settings.
  • Are you checking the playback in a media-player or in Premiere Pro?
  • Have you tried exporting your sequence in a different format?
Kulpreet Singh
maxleonardfarrell
I have tried checking it in vlc, windows media player, and by re importing to premiere.
And yes, I have exported to h264, mp3, and wav. None have audio.
When you import back to Premiere and place in timeline, do you see any waveform in the audio clip or is it flatlined? There is an odd circumstance that with a mis-wired microphone to the camera, one could have out-of-phase audio on the L and R tracks such that there IS audio, but the two opposing tracks cancel each other out so they become inaudible.
Thanks
Jeff
Post screenshot of export settings.
maxleonardfarrell
