No audio playback/audio meter not registering
Hey all. Desperately in need of help. Adobe Premiere has, for whatever reason, stopped giving me any audio playback at all. I know the clips have audio, and the wav forms show in the sequence, but when played, the audio meters don't register anything at all. No tracks are muted. I'm running the most current verion of '25, running it off a Lenovo Thinkpad X1. I didn't (intentionally anyway) change any settings. The audio works outside of Premiere so it has to be a software or setting issue. Any assist here would be great.
JonesVid
JonesVidCorrect answer
Not sure if you solved this yet, but have you checked your Track Mixer settings?.
See attached clip.
If the final mix slider has accidently been moved to the bottom (minus infinity) then the audio in tracks is there but no audio heard in the final mix and the meters are not working.
Just a thought
Send a screen shot of your track mixer if you still have  the problem
JonesVid
JonesVidCommunity ExpertCorrect answer
See attached clip.
Just a thought
