I guess that with mogrts, the same font used in After Effects by the author who created the mogrt must be installed
on your pc ... if its not, everything gets into chaos as far as I have experienced
now check this out from the amazing Premiere Gal :
Quick Fix: How to Open a Motion Graphics Template in Adobe After Effects - YouTube
jstrawn
If the AE user used a TypeKit font you will be prompted to sync that Font when you apply the mogrt in Pr. If they used a Font that is not TypeKit and not on your system then you will need to get the Font and install it.
As for the "Open MOGRT in Ae" tip, there is a quicker way in Ae 15.1. Go to File > Open Project > point to a .mogrt > click Open > Click Extract when prompted.
I have been having this issue with the "Bebas Neue" and it's driving me nuts. lol
I have done everything above. Even when I extract the file from the .mogrt and turn it into a .aep and open it up in After Effects to see what Premiere "thinks" the font is...it's in the CORRECT Bebas Neue! So then it is like I am screwed and have no idea what it is being switched out for in Premiere during the "essential graphics" translation.
So now I have to make everything in After Effects which defeats the whole purpose of me buying over 80 .mogrt titles to use in Premiere and MANY of them (about 90%) use Bebas Neue. Ughhh. Any ideas?
I'm wondering if this is the problem where some CC app like Illustrator installs with some Typekit fonts in its package/program files but they aren't actually installed on the OS font list.
You're gonna get that need to sync font window but it never can sync. The Adobe info says for unable to sync issues uninstall the fonts from the OS then sync.
But the fonts ARE NOT installed into the OS, so there's nothing you can uninstall.
Remove the fonts from Illustrator, and the refusal to sync still occurs.
James ... any progress on this?
I am having the exact same issue.  Has anyone found a fix?
Have you tried just canceling that dialog?
I have but it makes no difference.  The font never loads.
I have the fonts needed selected and setup in TypeKit but it keeps coming up that it can't resolve the Bebas Neue font.  CC Manager shows it is synced though.  I even installed a local copy on the computer directly.
All was working great the other week, now suddenly things are totally messed up and the project was almost complete.
