No Sound in Premier Pro but Sound in Audition and everywhere else
  • April 6, 2018
  • 924 views
I have been using Premier Pro with my rig for a while no problem.
About two weeks ago, Adobe Audition started to fail to play audio. Here is what I mean when I say play...
1.) Yes there are audio files associated
2.) Yes the meters - both track and master - are reacting
3.) Yes the files play sound in other applications INCLUDING AUDITION
4.) No, I have not changed hardware
5.) YES the Audition and Premier Pro Hardware Setup are exactly the same.
I have cleared cache, uninstalled Premier Pro, rebooted and re-installed Premier Pro and still get no sound.
I have reinstalled the sound drivers.
HELP. I am backing up on projects...
    One other question to add to my list above.  Does Adobe no longer offer CHAT support?  I select the options Premier Pro, Trouble shooting and then select CHAT and is say select the option above.  I do that again and it removes CHAT as an option.
    All the money I pay for software and I cant get support?
    The best advice I can offer is to not use USB audio.  It has a history of being flaky.  Stick to the motherboard audio or installed sound cards.
    I tried both motherboard and USB same problem
    Sent via the Samsung Galaxy S8+, an AT&T 4G LTE smartphone
    PS I am using a PC with Windows 10
    Dual Xenon
    16 gb ram
    Focusrite 2i2 external interface
