Dec 23, 2025 9:15 AM UTC
No Sound when importing m2ts file with Dolby Digital audio into Premiere PPro
I know that this problem was discussed in another thread already but I post it here anyway.
I am currently on PP 25.6.3 on a Windows 11 PC
When I am importing a .m2ts file with Dolby Digital audio there is no sound in PP. When I double click on the .m2ts file OUTSIDE PP the video plays back perfectly with picture and sound in Windows Mediaplayer.
Any solution?
Dec 23, 2025 11:48 AM UTC
Thanks, Ann.
I am a bit puzzled now. Why would one file have sound when imported and another one stays mute when imported (see attached screenshots in my second message. Also I am pretty sure that I do have the AC-3 codec installed on my Windows 11 machine.
Peru Bob
Dec 23, 2025 3:52 PM UTC
Try downloading them from the camera again?
Dec 23, 2025 4:00 PM UTC
Why?
The problem is that both .m2ts files do have AC-3 audio. In one case the audio is not imported into PP, in the other case it is. If I play those .m2ts files outside of PP both videos are played back with sound.
Dec 23, 2025 11:03 AM UTC
W11 does not support ac3 audio any more
You need to convert the files (eg Prores) or install the ac3 codec.
Download Dolby AC-3/AC-4 Installer - MajorGeeks
Solved: No AC3 codec in Windows 11 24H2 - Solution is need... - Adobe Product Community - 14972524
Dec 23, 2025 9:59 AM UTC
I found that certain .m2ts files are imported with sound, others without. I have made two screenshots. The first shows the media info of the file which is imported without sound, the second screenshot is the one which is imported with sound.
