Noise Reduction
Did Adobe remove this feature?? I use PP occasionally and will not be paying for any third party nr software. It would be horrible if they removed a feature that worked well in previous versions.
The only alternative I can think of is to export as images, batch process in Lr or Ps, then import again. Obviously that's a massive headache.
If they did remove it, what version do I need to revert to? (so far this 2023 is all headache)
