Not able to link DJI 4K Drone footage in Premiere Pro CC
  • December 2, 2018
  • 650 views
All,
Need help urgently.
I had a problem importing DJI 4K Drone footage in my Premiere pro cc and creating proxies, so I used a friend's system to create proxies. But, after connecting the external hard drive to my Premier Pro CC, when I open the project file, it says that 'Media media files for these clips' and when I try to locate the files manually and link them, it is giving me the error as 'The importer reported a generic error'. This works perfectly in my friend's machine, but I am facing this issue. Can anyone please suggest on what I need to do? I don't have any problem in playing the 4K drone footage, so there is no issue with the drone footage as such. I don't face the same issue when I am working with 4K footage from anything other than drone
My OS is Window 10 Home edition (64 bit).
Shyam
Right click on a clip in the project window and Attach Proxies.
Or are you trying to link the proxy file to the original?
Hello Ann,
Thank you for your quick response. I did what you suggested and able to make progress with my edit, but when I export media, it is only giving output based on the proxies, but not able to render based on the original 4K footage even though I toggled off the proxies before exporting. How do I solve this?
Shyam
Export is always based on the original footage. Pr does not use proxy files for export unless you deleted the original or replaced the original with the proxy files.
