NTTDLL.dll crashing when using adobe premiere pro and after effects. How to fix it?
  • March 31, 2024
  • 4 replies
  • 1422 views
I have been experiencing regular application crashes and blue screen of death (BSOD) for the past month. I assembled a new PC in February and since then, it has been crashing frequently whenever I use Adobe software. Here are my PC specifications:
Windows OS 11
Intel i9-14900K 3.20 GHz
Gigabyte Eagle 4080 OC and NVIDIA GeForce RTX 3060 - Galax
Corsair 5200 MHz DDR4 RAM 32*4
MSI 790 Pro Wifi
Crucial P3 500 GB SSD for OS
Crucial P3 1 TB OS for project files
1000 watt Deepcool 80 gold SMPS
Initially, I assumed it was an issue with Adobe software and contacted their support team, but they were unable to resolve the issue after several hours. I then reached out to the Windows customer support team, and they recommended that I reinstall the Windows OS. I followed their instructions, but the applications still kept crashing. I also ran a RAM test, but no problems were found. To troubleshoot further, I downgraded my new GPU with an old one (3060), and it helped me to open the application initially rather than crashing whenever it tried to open. Although it was a small improvement, it was still unstable. I updated the MSI bios, turned off XMP, but the crashes persisted. Even if I tried to edit a new project, the software just kept crashing. After browsing some forums, I found that my home power might be causing these crashes if it's not sufficient since I am powering three monitors and the CPU from one socket in my home. So I connected my CPU to a separate 20 AMP port, and this almost reduced crashes to 80%. However, these crashes are still occurring regularly. I decided to try editing with different software, so I attempted to use DaVinci Resolve, but it also kept crashing. I have already sent my 4080 for warranty check just to see if the GPU had any faults. I ran a RAM test twice, and no issues were found. I spent several hours with Adobe and Windows customer care, but it didn't help at all. I tried to stress test both the GPU and CPU for a longer time to check if the crashing was happening, but it was stable. No problems at all. Whenever I started with Adobe, the problem occurred. I did a clean installation of both Intel and Nvidia drivers at least 25 times, but it didn't help. When checking some dump files for software that crashed, I found out that the issue was happening with the ntdll.dll file. But I'm not able to fix that either. The BSODs are coming with PAGE_FAULT_IN_NONPAGED_AREA error.
Here link to dump files and BSOD details :
Can anyone help me with something here? Or is it like that windows will be always like this?
Correct answer Kevin J. Monahan Jr.
Hi @MTW MEDIA,
I'll move this post to the Discussions forum for further troubleshooting.
Hi @MTW MEDIA,
Hello @MTW MEDIA,
Thanks for the bug report. It's been a while since you filed it. Are you still having this issue? Please let the devs know. Take care.
MTW MEDIAAuthor
Am attaching some crash reports. It may help find some details
MTW MEDIAAuthor
I wrongly put DDR4. Its DDR5 actually.
