Open captions not visible after rendering (Premiere Pro 14.9 and earlier)
  • January 24, 2017
  • 36 replies
  • 70615 views
Hi!
I'm new to the Captions option in Premier Pro. I have 4 caption clips on the timeline with multiple captions in them. I can see the captions in the program monitor and also see the style changes I made to the text. But when I render the footage on the timeline, the captions disappear. What could the issue be?
Thanks!
Correct answer Kevin J. Monahan Jr.
An update solved this particular issue for a majority of our users. If you have similar issues with captions, kindly create a new post and do not create an additional post here. That would help us triage only existing issues, not ones that have been addressed.
Thank You,
Click on the wrench icon in the lower right of the Program Monitor, then select Enable Captions.
Greg Jones
Anthony03238
Hi Greg,
Captions was enabled at the first place.
The problem is, after I sent my project to render and came back continue my work in Premiere Pro, all the captions were invisible until I restarted the Premiere Pro and reopen my project file.
Hope Adobe can fix the bug soon.
Anthony
FuturelineMediaDenmark
Hey Adobe. It's time to check in....
... this i a disaster, for us, having customers ordered this product, but now we can't deliver. What is the solution for this????this is really NOT good enough. After hours of trying and cruising forums, i found this. The nesting ALSO worked for me, but this is really, really unacceptable! Remember to render the NEST and of course the sequence.
Anthony03238
I have tried to restart Premiere Pro, it works. After restart, the caption came back visible and seems normal.
Nesting the captions and then render the captions within the nested sequence "render in to out" did it for me.
Works for me also.
Or...
Export direct from Premiere.
T
kre57
So here's what worked for me using PP and ME 2017.0.2. I used .srt files, nested them in the timeline, then when encoding in ME, I went to the captions tab and selected "Burn Captions Into Video" from the dropdown menu.
CIS1
kre57​ I haven't tried captioning lately on the newer versions, but when I was trying to export I was selecting the "burn in" option and it seemed to only work 25% of the time. I tried different things like clearing rendered files, exporting immediately after open, adding to queue vs direct export, and nothing seemed to be a trigger.
At the moment I'm using different software to caption, so that's my solution.
kre57
S.Lavi, Did you nest the caption clips before you rendered?
Rameez_Khan
Hi steffp85,
Were you able to get around this issue or do you still need help?
Rameez
SF2010Author
Hi Rameez,
No not yet, unfortunately. I did update Premiere Pro a couple of days ago. That might solve the problem, but I haven't tried it yet. Do you know more about this issue?
Stef
Rameez_Khan
Hi Stef,
There were some bug fixes for Titles and Captions in the latest 11.0.2 update.
However, your issue seems to be different. Let us know if you still have the problem so that we can troubleshoot it or log a bug for it.
Best,
Rameez
SF2010Author
And I now see that some of the captions disappear from the clips...
jasontcox
Just to make sure - you definitely selected Open Captions from the New Captions dialog box and not Closed Captions? And did you double check the Captions tab in the Export Settings box?
SF2010Author
Yes I have selected Open Captions. I have not exported the video yet, but tried to render a preview. I can see them when the clips in the timeline are unrendered. But the captions disappear after I render the sequence.
