Optical Flow Export Issue on M2 machines
HI, I have a few M2 Studio Macs I use for editorial purposes. Whenver I try to use Optical Flow to slow down a clip, the exported sequence will have a "glitchy" effect on the effected clip. I have tried using "Intel" and rendering the clip before exporting but have had no luck. Is this an issue anyone else has been having? And is there a solution for this?
Thanks!
