optical flow not rendering with 'render in and out'
  • October 17, 2023
  • 664 views
When I slow down a clip and set it to optical flow, make my in and out selection in timeline and select 'render in and out' it renders but optical flow doesn't take effect. The footage is still choppy. I know optical flow is applied to the clip because if I export the in and out sequence, it very clearly has optical flow on it. I have a core i9 13900K, 4090, and 32GB RAM so hardware is clearly not the issue here.
MarekMularczyk
Is this happening with all videos you're slowing down? Is this happening with different sequences, too?
Adobe Community ExpertAdobe Certified Professional
Kartika Rawat
Hi there!
Sorry to hear that. Which version of Premiere Pro are you using? What type of media files are you using(codec/ format, frame rate, frame size)? Could you share the screenshot of the export settings?
Let us know.
KR
Moved to discussions
