echy5
optical flow smudges frames in after effects/premier problem
  • June 15, 2019
  • 586 views
so i follow the youtube videos, about slowing down videos, changing velocity, and getting a higher frame rate
all these videos have something in comon which is adding optical follow to blend the video frames well togther
the thing is when i use optical flow for some odd reason i end up getting a smudged frames...
the bottom picture is a good example.... i tried to convert the 23 fps video to 60 fps
this gives me these weird smudges for the frames it tries to guess and not clean ones, this is really annoying
Optical Flow isn't perfect.  In this case, you won't be able to use it.
