milana27734870
Parasite constant noise - Mic audio track
  • December 27, 2019
  • 1317 views
I'm having an issue with the voice audio track (recorded for an interview). The original file is perfectly fine but as soon as I import it on my timeline, a constant "beep" noise appear, (just like after a grenade explodes in movies (; )  and when I export my project : nothing, perfectly clean !
It's very annoying since I need to listen this track for a very long time.
What I've already tried :
- Change audio output
- Create new sequence and a new project
- Try to pre-render with audio rendering enabled
- Unlink/relink the media source
- Tried different computer
It's the first time I have this issue and I couldn't find a solution... If anyone has an idea, it would be very nice !
Thank for your answer 🙂
Best regards,
Milan.
John T Smith
Please post the name of the Adobe program you use so a Moderator may move this message to that forum
milana27734870
I'm using Premiere Pro 2020
PZO Claw
Since you are using Premiere Pro 2020, does it glitch or have any issues?
Here are some problems with the new update with Premiere Pro 2020:
  • Issue: Learning panel can display upper half of workspace as black.
  • Workaround: Revert to a saved layout.
  • Issue: When trying to edit text in essential graphics, certain Japanese fonts change to Chinese fonts.
    Workaround: Switch to Japanese font manually.
  • Issue: Remote desktop access of Premiere Pro and Adobe Media Encoder with Windows 10 version 1903 can hang when focus is changed.
    Workaround: A) Do not use remote desktop OR B) set Remote Desktop Audio preference to “no audio”. This option results in no audio being heard through the Remote Desktop.
PZO Claw
Do you have any digital connections to your system (anything on SPDIF, AES/EBU, Lightpipe)? If yes, I suspect a clocking issue.
milana27734870
Thank for your answer,
No I don't... And the noise is present on my laptop and it's the same for my main computer.
