Pitch Shifter Distortion in Premiere Pro
Facing this issue in different projects therefore can't achieve a good result.
I edit video in Premiere Pro CC2022 and when the project is done (mainly talking head)
I create a new sequence where put already finished sequence and speed up video and audio about102-106%
Of course, audio sounds unnatural and I apply pitch shifter. I've tried "Maintain Audio Pitch" it works even worse.
For some reason, pitch shifter randomly distorts audio during playback, and if I play this part one more time I hear no distortion, but it reveals in a different part of the audio.
This option works much better in Final Cut Pro. Hope to have it in PP.
Maybe you have some recommendations on how to fix it?
P.S. I can make 2 renders and this distortion can be in two clips but different places.
