Jun 18, 2025 6:01 PM UTC
Playback Speed keeps changing itself, audio hardware fix doesn't work
- Using Premiere Pro, no addons or plug-ins or anything.
- Latest version of Premiere pro as of 06/18/2025 through Adobe Creative Cloud: v25.3
- Windows 11
I just want the playback to play at normal speed and stay there 😞
> Somehow, it started playing at 2x the speed
> I struggled (valiantly) with the JKL buttons to get it back to exactly 1x speed
> I go home from work
> cue me opening up the program again after restarting the computer and its at 2.whatever speed again
> this is driving me crazy
I tried the magical audio hardware fix that works for everyone else, but not me 😞 please help if you can. What I can do to fix it. Or if you have a "press the L 4 times, then the K two times and that'll always get you back to normal playback speed", I'd appreciate it so much
Adobe Employee
Jun 18, 2025 6:22 PM UTC
Hi there,
We're sorry to hear about this. We can get this checked. Is this happening with any specific media/sequence or all of them? Is the playback in Source monitor also affected? Please, also share a screenshot of the Audio Hardware preferences window. We're here to help, just need more info.
Sumeet
Jun 18, 2025 6:50 PM UTC
Hi Sumeet, thanks for your reply
- It is happening with any sequence or project for Premiere Pro
- yes, both the audio and video in the source monitor are synced at the high playback speed
I have attached a photo of the audio hardware as requested  : )
Adobe Employee
Jun 19, 2025 10:05 AM UTC
Thanks for the details. For testing purposes, please try to create a new sequence from Bars and Tone or Transparent Video (File > New > Bars and Tone / Transparent Video) & let us know if that is playing at normal speed.
-Sumeet
