pr audio waveform after scaling inconsistency, dislocation and other problems
  • June 26, 2024
  • 6 replies
  • 324 views
Waveform problem: The waveform will suddenly become irregular, and it will recover after shrinking and enlarging the timeline for dozens of times
This problem persists after all caches are removed and the system is reinstalled
System Version: 14.5 This device is the M1 chip 2002 Mac Studio version: v24.5 No plugins installed
Hi @子恒38234715gzbg,
Are you still having the issue with v.25.0? Let us know.
There is still this problem, I have tried different projects, and I have not found a solution in the community.
The status of this bug report has been updated.
The two images are audio strips and the second image is the enlarged version
Hi 子恒38234715gzbg,
Thanks for filing this bug report and for giving the team your information. It's been a couple weeks since you filed the bug. Are you still experiencing it? Have you tried different footage? Let the community know. I hope we can help you shortly.
pr Version :24.5   Attached map
